It is currently Sun Jul 20, 2025 7:01 am
PostPosted: Sat Dec 30, 2006 12:17 am
Last Name: Johnson
State: CO.
Zip/Postal Code: 80224
What do you use for the hard sanding blocks used for sanding w/o variations in depth.
hardwoods? ebony etc.?
3/4" baltic birch plywood?
I have seen mention of plastic?
PostPosted: Sat Dec 30, 2006 12:33 am
I use birch ply, MDF, or hardwood scraps. Sometimes I laminate one surface with thin cork for just a little give.
PostPosted: Sat Dec 30, 2006 2:26 am
Birch Ply or MDF, has to be flat tough.
PostPosted: Sat Dec 30, 2006 3:50 am
Whatever I have that's flat.
PostPosted: Sat Dec 30, 2006 4:38 pm
I use a hard rubber sanding block, flat on the bottom with an arched top that fits in the hand nicely.
PostPosted: Sat Dec 30, 2006 5:27 pm
I use a cut off from an old stair ramp, it's rounded nice on the top for the comfort of the hand and flat at the bottom. Got a bolt and wing nut a la Lee Valley, looks a lot like theirs, check here because i don't have a pic of mine
http://www.leevalley.com/wood/page.aspx?c=1&p=20184&cat=1,42 500,42523&ap=1
PostPosted: Sat Dec 30, 2006 5:32 pm
First name: Louis
Last Name: Freilicher
City: Belchertown
State: MA
Zip/Postal Code: 01007
I use Acrylic, some with thin cork on one side.   My latest addition for
leveling necks and fingerboards is the rear part of an old #7 Stanley plane.
Louis
- Louis Freilicher
PostPosted: Sat Dec 30, 2006 10:03 pm
Last Name: Johnson
State: CO.
Thanks all, great ideas, as usual
PostPosted: Sun Dec 31, 2006 3:36 am
I have blocks made from all kinds of stuff. I probably reach for my little corian blocks most often though. These are just little different sized pieces of corian that have sticky back paper on then and are really handy for getting into those odd places I am always running into.
PostPosted: Sun Dec 31, 2006 4:04 am
That's a great idea Hesh (the thumb tacks)
Nice purple paper you got there, goes well with Hesh the purple Dinosaur
